Saltar al contenido principal
El iPhone 5s de Apple fue anunciado el 10 de Septiembre, 2013. La reparación de este dispositivo es similar a los modelos anteriores y requiere destornilladores y herramientas de palanca. Disponible como GSM o CDMA /16, 32, o 64 GB / Plata, Oro, y Gris Espacial.
Preguntas 3530 Ver todo
No screen,no sound,even not itunes cant detect my phone
Hey guys,i wanna ask you a question about my phone,today i wanted to replace my screen and battery (which i ordered and will be delivered next week),but just wanted to see first the phone inside,i read the guides here on the website and watches videos about it,i got out the screen successfully and the battery too,but after i placed the battery back and the screen without the metal brackets,just to see the phone is working,it doesn't give any sound or anything when i plug it to my pc,i know it's a dumb question as i am,but i dont know what to do now,i dont think i ripped any cable or connector cuz i was working with plastic tools and i was aware of having this problem..should i wait for the new screen+battery and try with those or did i did something wrong?
Es esta una buena pregunta?
Puntuación 1
6 comentarios
can you post photos of around the connectors
- de
check the charge port ribbon, make sure you didnt loosen it when disconnecting the battery also just goe over the connections again to make sure they are all connected properly
- de
https://imgur.com/a/Fo0pI there are the pictures i took of the connectors
- de
Maybe i damaged something on the main board?Can i even damage something on it while screwing and having my hand slipped and getting something damaged?
- de
I didn't apply any pressure to the battery..i could try hard resetting,but my home button is not working,it didn't work since summer,i wanted to repair this too..
- de
Mostrar 1 comentario más
Agregar un comentario
2 Respuestas
Solución Elegida
How did you remove the battery; did the pull tabs work properly or did you have to pry the battery out?
There are some components near the edge of the logic board, just above the Dock connector, which can be damaged if you apply pressure to pry the battery. Most of those passives are related to the Audio Codec IC...
Fue útil esta respuesta?
Puntuación 1
Try checking the ribbon cables near the dock connector. You might have damaged one of them. The next best bet is that you damaged the logic board. Good Luck Fixing.
Puntuación 0
Añadir tu respuesta
B. Andrew estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 101
