Saltar al contenido principal
Modelo A1286. Lanzado en febrero de 2011 / 2.0, 2.2 o 2.3 GHz Procesador Intel Core i7 de cuatro núcleos
Preguntas 586 Ver todo
Progress bar on start up screen stuck and screen is frozen.
When turning on my computer, the progress bar on the white startup screen with the apple logo in the center, gets stuck 3/4 of the way and the screen freezes. I tried option-command-p-r and was not successful. Thanks for your help!
Es esta una buena pregunta?
Puntuación 2
2 comentarios
I had a ѕіmіlаr issue, when turning on my Mасbооk Prо used to freeze.
During startup the progress bar would get stuck.
Fіnаllу I mаnаgеd tо rеѕоlvе thе рrоblеm.
Follow thіѕ ѕоlutіоn hеrе: http://bit.ly/MacBootStuck
Hоре thіѕ hеlрѕ
- de
The link provided above for its solution does not work. Please kindly update.
- de
Agregar un comentario
2 Respuestas
Solución Elegida
That's about where the GPU driver kicks in. See if it will boot in Safe Mode (hold down the Option key On start up). What OS X are you running?
Fue útil esta respuesta?
Puntuación 4
3 comentarios:
We are not sure...
- de
OK, what did it do in Safe Mode?
- de
While it is in Safe Mode, you should also run Disk Utility and run "Repair Permissions" if it exists, and "Repair Disk".
- de
I ' ve done it. But it doesn't work
Mise à jour (13/01/2018)
Wath's the next step. Please. Thanks for helping
Puntuación 0
Añadir tu respuesta
Kathy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 44,956
