My cq40 does not recognize my hard drive
my cq 40 does not recognize my hard drive, it does not come up in the BIOS, what do i do
Es esta una buena pregunta?
chimeziegordian if your BIOS can not read the HDD check the connection first. It is possible that your HDD controller has failed. You most likely will need a new HDD. You can also verify if your drive has failed if you get an external case to run the HDD as an external drive.
Fue útil esta respuesta?
try to replace the hard drive
or just move it around
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 542
