Saltar al contenido principal
Modelo A1369, procesador 1.6, 1.7 o 1.8 GHz, 64, 128 o 256 GB de almacenamiento flash
Preguntas 328 Ver todo
What WiFi bluetooth card to upgrade my 2011 MacBook Air?
What WiFi bluetooth card to upgrade my mid-2011 macBook Air? wifi card to be able to connect to 802.11 AC? My hopes are to enable Apple Watch unlock along with continuity and handoff under High Sierra. Anyone try this would this work? Are the antenna wire long enough to reach the new card? Are extensions available if not?
Would this be the correct part# BCM94360CS2?
Thanks for the help guys.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Yes, it will work. Make sure you get a dual-band card and purchase extensions just in case. Below is a replacement guide.
MacBook Air 13" Mid 2011 AirPort/Bluetooth Card Replacement
Update (11/28/2017)
That is indeed the correct part number, no extensions should be needed. Look in the guide I posted earlier to help you replace/reassemble your laptop after completing the replacement. Good luck!
Fue útil esta respuesta?
Puntuación 1
5 comentarios:
Thanks, That card is a different number and looks different is that the 2012 card? I think I need a mid-2013 or newer card to use Apple Watch unlock feature. Which is why I was looking at BCM94360CS2. Also, . where do I find the extensions?
- de
I updated the answer.
- de
Thanks, much appreciated
- de
I don't see a link to the extension cables you mentioned in your comment or the guide. I know I found a set last week, but I can't find it now. Can you help me out with finding them or what I should be searching for, please? thanks!
- de
This did not work for me, the BCM94360CS2 is a longer card than the original, there was no way to secure it once installed.
- de
Hey Jorge,
Did you do this yet?
I'm waiting for my BCM94360CS2 to come in the post.
I believe one of the antennas will be too short. you'll have to reroute it.
Regards,
Stephan
Puntuación 0
1 comentario:
Has anyone been able to get this to work? quicker tech is so dissapointing .
- de
Añadir tu respuesta
Jorge estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 43
Todo El Tiempo: 2,861
