Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
Preguntas 488 Ver todo
New iFixit Battery Not charging
I replaced my factory battery with a new iFixit battery. The new battery had 70% when installed, I allowed it to die and now I put it to charge and it stays at 2%. If I unplug the computer it turns off and has to reboot.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Sounds like your battery is not charging. I would suspect the mag-safe board right off the bat. What was happening with your old battery? Please download and install and run Coconut Battery then post your results so we can get a better idea of what is going on.
http://www.coconut-flavour.com/coconutba...
Fue útil esta respuesta?
Calificación 1
Comentarios:
The old battery was swollen, so I purchased an new replacement
por
macOS Battery Status: Good
Battery Failure: yes
Power adapter: 85 watts
Cycle count:2
Charging with: 0 Watts
Current Charge 136 mAh
Full Charge Capacity 6891 mAh
por
Well it shows to be a failed battery, which is unusual for a battery with only two cycles but it does happen. I would request a replacement.
por
Whats up with battery failures on iFixit batteries? this is probably the 2nd one i've seen today...
por
Right now I don't know if it is the battery. Looks like it was run for one cycle to test it before you got it. We won't know till you try a second one. It can very well be something else.
por
Mostrar 5 comentarios más
Añadir tu respuesta
Joseph Granger estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 10
Todo El Tiempo: 112
