The Viewsonic gTablet UPC300-2.2 is part of the first wave of Android tablets. It features a 1.3MP front-facing camera, 10.1" display screen, and runs Android 2.2 OS. There are a few common issues which can be readily fixed.
Preguntas 4 Ver todo
I can not enable the video mode
when the screen comes on a little display comes up in the top left corner that says video mode disabled. i have done the on volume button thing with no results
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Rob Vitale by this "done the on volume button thing " you mean a complete hard reset?
por
Ok. I hold the on button and hold the volume down button. It goes blank. Then it comes on for 1 second and on the screen it says that the UI launcher has stopped. Then freezes up. I did the same thing with volume up. It's not happening. All I wanted to do is clear the cookies and reset the app. preferences.
por
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Rob Vitale start with a hard reset. You will lose your files like pictures, music etc. when you do this.
You need to hold down the volume up button then press the power button for a few seconds until the tablet turns on, releasing power button, you should now be getting the recovery menu.
Fue útil esta respuesta?
Calificación 1
Comentarios:
after i did that. the screen came up with...magicware mismatch. critical failure, unable to start kernal. unrecoverable bootload error. whitch means is that it is stuck in a loop.
por
Añadir tu respuesta
Rob Vitale estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 2
Todo El Tiempo: 44
