Testing the ADP-200ER. How To?
Hi Team!
Much like the question title states, i am looking for a way to test the ADP-200ER.
---I have tested many of ADP-240ARs, however, i have run into my first ADP-200ER. I am aware of the relay check for the 240, where you hook up the Multimeter to the 12VDC, and short the relay to send the current. i tried that on the 200ER, and i didnt get a signal. i have no way of telling if this means its failing, or if the adapter does not have the same workings to allow that test.
---I plugged the powersupplies, 5VDC connector to the board, and hit the button. the Voltage shoots to 12VDC, then starts discharging immediately, even if i hold the power button.
I am looking for a verified test that is known to test these 200ER model of power supplies. please let me know if you have one. im looking into possible power failures for the "BLOD"
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
bumping the question up. im on a time crunch, and need an answer asap.
por
Agregar un comentario
