Saltar al contenido principal
Modelo A1040 / disco duro de 10, 15, 20, 30 o 40 GB / cuatro botones retroiluminados LED sensibles al tacto sobre la rueda táctil
Preguntas 97 Ver todo
Replaced battery but iPod still doesn't charge
I recently replaced the battery in my 3rd Generation iPod (A1040 20GB). It briefly powered up, worked and played music but the battery was low on charge and it quickly died. However, when I connected it to a wall charger it wouldn't charge. I have the same result when I connect it USB to a computer. I've tried several different kinds of wall chargers with the same results. When I plug it in it will briefly flash the Apple logo then go to a battery icon with a triangle with an exclamation point in it. I appreciate any help.
Thanks.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
5 Respuestas
Respuesta Más Útil
Are you trying to charge it via USB? You need to use a 30-pin to firewire cable and charger, or an iPod dock. The 3rd gen iPod can’t charge with a USB cable like the other iPods can.
Fue útil esta respuesta?
Puntuación 1
Have you tried replacing the charging port?
Puntuación 0
1 comentario:
I have not. I'll explore that option, thanks for your response.
- de
You can either try a MB with the charge port already on it or a new charge port by soldering. But that's the next step. It's been hard finding main boards for these these days though
Puntuación 0
2 comentarios:
By "MB" are you referring to the logic board? (IF192-001-1).
- de
Yes that's what I meant . MB short had for main board
- de
I have this same issue.
I found two burnt out chips next to eachother on the motherboard.
Puntuación 0
I’m having the same problem with my 15GB model, I’m thinking of replacing the dock connector and cleaning up the motherboard to avoid any possible shorting. You could try this:
Connecting the iPod to the FW charger without the battery (open up the iPod and disconnect the battery), if it turns on then the battery might be faulty.
Puntuación 0
1 comentario:
what is the fw charger i have one of these took the battery out was wondering if it could be hard wired to bypass the battery.
- de
Añadir tu respuesta
Brian Martin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 399
