Saltar al contenido principal
Modelo A1312 / Mediados de 2010 / 3.2 GHz Core i3 o 2.8 y 3.6 GHz Core i5 o 2.93 GHz Core i7, ID iMac11,3
Preguntas 382 Ver todo
Startup keyboard commands not working, only getting? folder
Hard drive is blank - trying to boot from a USB to install OSX - Mac isn't responding to any start up boot commands, have tried holding C down, tried the command to boot to recovery, tried the command to reset PRAM,
Recently installed a new logic board
Anyone got any suggestions?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
You might want to review if your OS install thumb drive is setup correctly. Review this guide: How to create a bootable macOS Sierra installer drive
Fue útil esta respuesta?
Puntuación 1
4 comentarios:
I'm not sure that's the issue - The machine isn't responding to any attempt at any of the startup key commands, even the ones that don't reference the thumb drive
- de
What kind of keyboard are you using? You'll need a USB one to access the Startup functions.
- de
Have tried 2 different USB keyboards, one apple and one generic
- de
If thats the case then you've likely have a bad logic board then. Why did you swap out the logic board in the first place?
- de
Añadir tu respuesta
Felix Wisniewski estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 111
