Saltar al contenido principal
Why do I have vertical lines of lighter color on my screen
Hey I have a un65ju7500 Samsung smart uhd tv. I've seen vertical black or colored lines on tvs before, this is a see through line. So the regular image shows through, but it has weird lines of a lighter white vertical strip/ line all over the screen, it's very noticeable on all grey or black screens. I've tried resetting, adjusting picture settings, nothing. I'm not sure what I need to do, please help. It's like rectangle sections of extra light. Could it be light bleed in lines? And the line don't move, same spot
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
It could either be a damaged LCD, a damaged main board or a loose ribbon connection between the two.
if your TV is under warranty period, contact the manufacturer for repair (basically a replacement of either the motherboard or the LCD)
if not, Open it (ensure it's unplugged) and see if re-seating or disconnecting the connection of the LCD to the Mainboard and reconnecting them.
if that doesnt work, consider contacting your manufacturer for replacement. See if the cost of the modules(s) is worth repairing them. From where I come from, repair practically costs more then buying a brand new.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
look at this link and see if your TV is listed:
Samsung Television
if not, just look at any of them. TVs have similar makes/components anyway.
just ensure they are unplugged, discharge the capacitors - touch the capacitors w/ a screw driver to avoid electrocution.
if you find this post helpful, pls tag it so others can refer to it for similar issues as well.
Thanks
- de
How do I tag on this website? And thanks I'll give it a try
- de
Añadir tu respuesta
Ethan B estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 22
Todo El Tiempo: 21,570
