Early 2011 model, A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor.
Preguntas 651 Ver todo
wifi weak signal problems
for the last weeks I have had a very weak wifi signal on my early 11 MBookPro
usually only at the first level in the signal strength bar
it will show full strength if shut off and turned back on for a few seconds, then down to the first bar.
I have version i7
does this have a replaceable wifi card? all other computers are not having this issue in our household.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
2 Respuestas
Solución Elegida
Hey Skiebuster, in my opinion the cable or Airport/Bluetooth card itself would be the first place to start. I'd suggest opening up the rear case to expose the proper components, inspect all connections. Re-seat all ribbons and boot to test. If no improvement then I'd be willing to bet the Airport card itself has degraded over time and cannot receive the signal properly anymore.. Be aware of any sudden impacts/drops also, this would definitely cause hardware issues.
Fue útil esta respuesta?
Calificación 1
Comentarios:
I found one of the antenna cables was broken. When I pulled it off it and loving it it just fell over and out.
por
That's excellent news skiebuster!!!
por
Respuesta Más Útil
I got this identical machine in yesterday with intermittent wi-fi problems. I ran Symantec Endpoint Protection Anti-virus on it and found 15 infections. As of right now, I am currently no longer having wi-fi problems but if I run into something else on it today I will let you know. I also have a new wi-fi part that I will check out if I experience problems.
Calificación 2
Añadir tu respuesta
skiebuster estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 5
Últimos 7 Días: 31
Últimos 30 Días: 159
Todo El Tiempo: 585
