The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
Preguntas 1483 Ver todo
Why my iPhone 5c is showing it's charging but doesn't? (not IC issue)
Hello,
I am into a real weird situation and i would really appreciate your help.
One friend of mine gave me for repair his iphone 5c cause it had faulty mic and home button. I replaced the whole flex cable (headphone jack, mic, charging port, home button metal contacts) with a new part. The fix was really smooth and didn't encounter any problem. Mic fixed, home button fixed. Next day i gave back the phone to my buddy (he was really happy with the result) but the day after that, he gave it back to me and said that the phone doesn't charge. I tested it again and the phone shows it's charging, can connect to pc and i can transfer photos without any problem. When it's connected the battery doesn't decrease. When it's not, it is decreasing like normal (no fast drain at all). I installed the old part again ( mic,home button faulty) and it is charging normal without any issue! I ordered another new replacement, installed it, exact same result.... I guess it's not the famous IC issue (microsolder) cause with the old part it's charging normal. I imagine it's incompatibility for some reason (but both new parts are original) ? For that thought i just ordered a new battery just in case but haven't recieved it yet. I 'll keep you updated when i recieve and install the new battery after 3-4 days but for the time being is there anything you could suggest me to do?
I have searched many days for a solution but it seems that i am the only one with that exact issue. I really don't have any clue what might cause this problem ( except from incompatibility). I am not a pro technician with any special equipment, just doing it for me and some close friends. Really sorry for my poor English it's not my native language.
Thanks in advance
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
i have tested it with 3 diffirent chargers that all of them are working on other iphones with no issue. 2 of them are original
por
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Bad replacement charging port assemblies. I generally tend to never order from the same supplier again to avoid having the same issue occur again.
Fue útil esta respuesta?
Calificación 3
Comentarios:
I bought them from seperate store too. Both shops labeled them as "original"
por
if it was updated to ios 11 it could be something to do with it as i take it you probably installed a non original apple charge flex
Calificación 0
Comentarios:
Has Apple started doing this now? Link to article?
por
i have no idea @sonnicham i was just saying as he said the old ( assume original ) does charge. but it could possibly be a bad batch of charge ports aswell
por
The problem is that both parts i bought were labeled as original. Is there a way i can verify this? The old and both new parts have the same code written on flex cable though. furthermore the phone is on 10.3 ios as well
por
Sorry for the late answer - No way to verify, but safe assumption is that it is not original. There are a ridiculous number of sellers claiming original, but the fact is that Apple has a very tight grip on their supply chain. Likely not original
por
Añadir tu respuesta
Dimitris Laskaris estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 51
