Not enough disk space? Need a backup solution? External drives provide you with extra storage in your office or on the go. Learn how to repair them here.
Preguntas 220 Ver todo
SD Card Photo loss - How to recover?
Yesterday I noticed that one of the albums in my libraries weren't there on my phone, so I plugged it into my computer to see if it’s there. But it looks like I mistakenly deleted some important pictures from my SD card. I need to get them back now! Please help!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
6 Respuestas
Try Recuva.
http://www.piriform.com/recuva
Fue útil esta respuesta?
Calificación 0
If photos are deleted from your SD card then it is not recoverable with the help of any manual method. You may need the help of SD card recovery software to recover photos from SD card.
Simply connect your SD card to your computer and run a SD card recovery software on your system. Follow the easy steps and you will recover your deleted pictures. You can download it free from http://bit.ly/2pYYzq9
Calificación 0
Hi,
There is no manual method through which you can recover your deleted photos from SD card. To recover them you have to use professional Photo recovery program. Connect the device to your system and launch the freeware tool first. Choose the Standard recovery mode, initial it will scan your complete device and shows you the preview of deleted photos. If you want to save them go for its license version and save all your lost photos at a safe location.
Download free tool - http://download.cnet.com/SysInfoTools-Ph...
Thanks
Calificación 0
Once I deleted photos from SD card, I tried RePicvid Free Photo Recovery. with friendly interface, it is easy to use for those without any technical knowledge. You can give it a try to recover photos from sd card.
Calificación 0
First of all DO NOT keep using your SD card, unmount and remove it immediately. If you keep using the sd card the data may be overwritten. Use a microsd adapter to plug in the card directly to your PC. Download and install Recuva and run a scan on the microsd card. If any files are found the program should be able to recover them
Calificación 0
Hello,
First of all I suggest you to stop using to your phone as it can be prone to further damage.
You can connect your SD Card to the system and try with a software… (For this download a third party SD CARD)
You can also avail SD card recovery services to recover deleted data such as photos, videos other documents from SD Card.
Calificación 0
Añadir tu respuesta
Ellinor William estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 0
Todo El Tiempo: 63
