Saltar al contenido principal
Esta Nintendo DS Lite se lanzó en 2006 como sucesora de la Nintendo DS. Entrar dentro de este dispositivo es simple, lo que facilita las soluciones.
Preguntas 314 Ver todo
My DS Lite screen edges are now starting to fade
My DS Lite screen hasn't been used for maybe 3 years because I lost the charger and I just recently bought one. Now, its fully charged but the screen (both the top and bottom) now has like weird stains and it makes the edges turn white when I turn it on (refer to attached photos for reference). Help. How do I fix it? DO I clean it? If not, where can I get it fixed? Where do I buy a new screen? Help!!
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Hi!
Unfortunately there is no other fix than replacing both top and lower screens.
However, the parts you will need are fairly inexpensive and the repair processs should also be easy.
I have linked all the parts you will need for this repair and our iFixit guide on how to do it.
You will need: the Upper LCD, Lower LCDand the touch digitizer for the new lower LCD.
Here's the guide for the Lower LCD, this one's for the upper screen.
You will also need this special screwdriver to open it up.
Imagen de Nintendo DS Lite Pantalla Táctil
Guía
Reemplazo de la pantalla táctil de Nintendo DS Lite
Dificultad:
Moderado
30 minutes - 1 hour
Imagen de Nintendo DS Lite LCD Superior
Guía
Reemplazo de la LCD superior de Nintendo DS Lite
Dificultad:
Difícil
2 - 3 hours
Fue útil esta respuesta?
Puntuación 2
Añadir tu respuesta
Hunnis estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 22
Ultimos 30 días: 161
Todo El Tiempo: 8,650
