Saltar al contenido principal
Rear Camera Problem - SW or HW problem?
Hello,
I've got an iPhone 5, It's old, I know, but I'm (was) happy with it.
I've got a problem with Rear camera - see picture.
Sometimes It's working, sometimes it's just black screen (most of the time) and sometimes problem showed in picture occurs.
I have replaced rear camera, restored the phone (deleted, then set it up as new, downloaded apps from App Store)
I don't know what to do next to fix it - is it software problem, or hardware?
It seems like software problem - camera works after restart, but when I start using some of my Apps, it stops working. Then only front camera works. When camera is not working, torch (LED flash) doesn't work too.
Thanks for help,
Dominik Pecháč
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Do you know if the replacement camera was working or was it purchased new? Using known-good parts is important for troubleshooting and "new" cameras don't all work either.
With a complete reset of your device, I highly doubt it's a software issue. If you can get your hands on a known-good camera, that will help you determine if the problem is with the camera or the logic board (which is what I suspect). Have you dropped your phone recently or has it been repaired or come into contact with water?
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Replaced camera was working (took out from other iPhone)
Phone was dropped sometimes, this problem occured sometime in june/july.
I don't know about some contact with water, except little rain or sweat, no visible corrosion on motherboard. I'm repairing my devices by myself.
I will try to reset it again and use without any apps and see what will happen. I sucpect Snapchat of making this problem. I will see.
Thanks,
Dominik Pechac
- de
Añadir tu respuesta
Dominik Pecháč estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 144
