Released September 25, 2015. Model A1687/A1634. Repair of this device is similar to previous generations, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 64, or 128 GB / Silver, Gold, Space Gray, or Rose Gold options.
Preguntas 534 Ver todo
Cracked screen and stops working suddenly
I dropped my phone and cracked the screen. A small chunk of the white part came loose so I put steri strips over it to hold it until I get a replacement glass ordered. I have procrastinated far too long because it was still working perfectly until a couple days ago. Now the screen sometimes goes blank and it suddenly stops working. It will say there is only a partial charge but as soon as I plug it in it says 100% charged, and the apple sign pops up and it will work again. Do I need to replace the whole LCD and digitizer too (not just the screen) or does this sound like the battery has seen better days anyway?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Solución Elegida
You can go HERE and download 3Utools. It is a free program you can download to your computer. After downloading and opening the program, plug in your Iphone and it will detect it and give you information about your battery life. Also click on the link next to your battery life reading and it will give you detailed information about it...
You can get a quality replacement screen HERE on IFixit as well as the Battery.
If you discover that your battery is in need of replacing and you are pretty handy with a multi Meter, test your charging port (You can google how to do it) to make sure it is charging your battery correctly... you can clean out the port itself if it needs cleaned (It collects debris like a "Belly Button" Lol) and can prevent it from making good contact to properly charge the battery.
Lastly, there is an IC Chip on the Logic board called Tristar (U2) that can go bad (Especially if you use generic chargers instead of the original Apple charger) and can cause "Fake charging", Poor or slow charging and no charging at all. If that is the case, you can google the chip replacement repair and watch a few videos on the process and try to find a local (reputable) shop that does Micro-Soldering near you or even find one HERE on IFixit that you can Mail in your Iphone for repair. Most have a No Fix No Charge policy like I have and is relatively inexpensive.
Feel free to reach back out here for more information or just to leave a comment on what you did to repair your Iphone to help others in the community troubleshoot their similar issue :)
Imagen iPhone 6s Plus Replacement Battery
Producto
$24.99
Imagen iPhone 6s Plus LCD Screen and Digitizer
Producto
$0
Fue útil esta respuesta?
Calificación 2
Respuesta Más Útil
iPhone screens are always replaced as a whole, never separate these days.
Whole display assembly and battery needs to be replaced.
Calificación 2
Añadir tu respuesta
aknorton estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 4
Últimos 30 Días: 4
Todo El Tiempo: 47
