The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
Preguntas 678 Ver todo
Is my PS 3 Power supply unit damaged?
Hi, my PS3 was hit by a sudden power surge when I was watching YouTube on it. Now it won't power on and only flashes the usual lights then off it goes. Is it possible that my psu has been damage? The power supply unit is aps 226. Ps 3 is 1st gen 80 gb. What screwdriver would I need to pull the psu and what kind of damage or signs should I look out for when inspecting it.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Hi!
It is very likely that your PSU has been damaged, tho other damage to the main board should not be excluded...
Use our guide here to get to the PSU. Once there, you have to figure out how to remove the metal case it's in, but it shouldn't be difficult. Look for any blown capacitors - actually any sign of burns. I think you may be able to replace whatever is broken with basic soldering skills, but don't quote me on that. If you find not signs of damage, I'd suggest that you simply get a new PSU...
Fue útil esta respuesta?
Calificación 1
Comentarios:
Hi, will inspect it and see if it is really just the psu or and the motherboard. Thanks.
por
Añadir tu respuesta
David Butler estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 6
Últimos 30 Días: 26
Todo El Tiempo: 103
