PC laptop by Dell with a 15.4" display. Succeeded the Inspiron 1520.
Preguntas 80 Ver todo
Why can't my Dell Inspiron 1525 charge the replacement battery?
Battery doesn't hold any charge.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
Is it a new battery that you're trying to use?
por
No, it's an old replacement battery and the electrical cord is used as well. Has been worked on prior times, not me. Trying to save the laptop since it's my only backup and my Mac doesn't have microsoft cause I can't afford to buy the approved programs.
por
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
2 Respuestas
Solución Elegida
Ok so what I would do is look for a replacement battery on Amazon, like this one:
Dell Inspiron 1525 Battery - Amazon
Try using that, and it should work just fine.
- Jasen
Fue útil esta respuesta?
Calificación 3
if Ur useing a new battery then u probably need to replace the charger port
Calificación 0
Añadir tu respuesta
Maria estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 4
Últimos 30 Días: 14
Todo El Tiempo: 69
