Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
Preguntas 502 Ver todo
Bootloop, Screen slightly messed up, and a little bent.
So, I have a friends iPhone 7 they gave up on (Actually it was their moms first). Despite all the problems it has it still looks pretty clean and it let me reset it. Looks like someone changed the screen, even the buttons still work... it is missing a screw for the battery cover.. would that cause the bootloop even after reset? Should I just Junk it? lol, Still fixable ?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Respuesta
Solución Elegida
I certainly wouldn't junk an iPhone 7 without at least trying to fix it. A lot of things can cause boot loops and because this phone was previously repaired, there is probably a link between the two. You really should explain more about the bend and what exactly is "a little messed up". Perhaps a picture would be helpful.
Unless you have some modular issue, such as a weak battery or defective screen, this phone will most likely have to be looked at by an experienced micro-solderer.
Fue útil esta respuesta?
Calificación 1
Comentarios:
It's a slight dent into the right side in between the sim and power button. I can post pics tomorrow. The screen has lines through it and green on the side... if you can picture my description lol. Thanks for the feedback, as I said I'll post pics tomorrow. Hopefully it's not that bad I need a micro-solderer.
por
Añadir tu respuesta
Shaolin estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 1
Últimos 30 Días: 6
Todo El Tiempo: 78
