Saltar al contenido principal
Modelo A1297 Unibody: principios de 2009, mediados de 2009, mediados de 2010, principios de 2011 y finales de 2011
Preguntas 544 Ver todo
Early 2011; How do I replace the trackpad?
I have a MacBook Pro 17" Early 2011. The trackpad barely works and I would like to replace the trackpad, but don't see any manuals / steps on how to do it. Understand that the actual part is about $60. Need help!!!
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
Check the battery for swelling first. 90% of the time it is the battery and not the trackpad giving you the problem.
UPDATE
Replacing the trackpad is very simple and essentially the same on all models of this era.
This guide, even if it is for the 13" should walk you right through it.
MacBook Pro 15" Unibody Mid 2012 Trackpad Replacement
Fue útil esta respuesta?
Puntuación 3
2 comentarios:
The battery is fine; no swelling.
- de
Mayer ... thanks for the manual!!! I'm going to give it a try after I order the trackpad off of Amazon. I'll let you know if I'm "successful" or will need to buy another MBP. Appreciate your help!
- de
Añadir tu respuesta
Maputo59 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 148
