Released September 16, 2016. Model 1660, 1778 Available as GSM or CDMA / 32, 128 or 256 GB / Rose gold, gold, silver, black, and jet black.
Preguntas 498 Ver todo
digitizer only works when touching frame
Hello, I have fixed hundreds of phones and after replacing the first time Screen on and Iphone 7, I noticed the digitizer works great but you have to be holding the phone. If you put the phone down and try to use the digitizer, it will not work.
If I have the phone on a table and touch the metal frame it will work but only touching the glass the digitizer doesn’t respond.
I a guessing it is a ground issue, but was wondering if anyone else has a solution.
Thank you
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Respuesta
Solución Elegida
It sounds as if you just have a faulty replacement. If possible, try the old screen (IF WORKING) or another replacement screen to see if you are experiencing the same thing. I have not personally had this happen to me yet but googled the issue and found that the majority of replies suggest replacing it as a bad display after testing with a known good screen as a troubleshooting check.
Let us know what you find to help the others who may experience the same thing...Best of luck!
Fue útil esta respuesta?
Calificación 1
Añadir tu respuesta
Patrick Romcoe estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 36
