Help Set up wizzard
I set up a Google account
Password
I have WiFi network connection
And when I click next is loading and then
It pop up a message saying !!!!!!!setup wizard has stopped!!!
Es esta una buena pregunta?
Password
I had the same problem. To log in dont put any info in at first( no wifi, name, ext) , then when you are in thats when you can fill all of it in
( do allow setup wizard)
Fue útil esta respuesta?
here is the fix to this problem on the Digiland DL-7006 and may work on others as well. follow steps carefully.
First power off the tablet
Second press and hold volume down and power until the digital screen appears
Third as soon as digiland screen appears press volume up, down, and power repeatedly over and over
Fourth use the volume down to select the Chinese symbol third from bottom with Emm in it
Last wait for tablet to power on, it will take a while. When it powers on skip everything. Do not connect to Wi-Fi or set email or tablet pin, SKIP EVERYTHING
tablet should unlock and you can set it up from settings >accounts *add account
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 4,061
6 comentarios
How do I setup my tablet wizard keeps popping up
- de Letucia Muse
Hi have yuou been able to set up ur device
- de Jazinae Jamison
I'm having the same issue. How do you reset back to the factory settings to be able to start all over again
- de nyob
Have you figured anything out having the same problem
- de Steven York
Trying to set up the wizard on my tablet and it keeps on saying the wizard has shut down I don't know what to do
- de Shari Wymer
Mostrar 1 comentario más
