PS4 stuck in safe mode
Everytime i turn ps4 on it checks system storage status then goes to menu tells me cannot start ps4 connect controller and press ps button then it tells me i need update file version 5 and i put i USB with update file it tells me update file cannot be used error code CE-34788-0 but when i start PS4 in safe mode (7 seconds on power button) it installs the update but after restart safe mode again please help
Es esta una buena pregunta?
8 comentarios
Cuento con el mismo problema, sin embargo realizo todo el proceso de colocarle el USB reconoce la actualizacion pero me queda la pantalla en negra despues de realizar todo el proceso , alguien con alguna informacion?
Gracias
- de Jorge Chavarria
Did you find out how to fix?
- de pinkydidit
I have a fix for you, mine did the same thing. No need to buy new hard drive.
Before doing anything go to safe mode and do the ps4 initialization, if you want to safe your games and stuff plug in your usb to transfer it all on there. Once PS4 is now cleaned and as no games or anything on there turn PS4 off and unplug it, then turn it upside down and on the back left there’s a clip bit you can take off, take that off and then you can see your hard drive, blow on it and push it in further then blow onit again and it should be okay
- de kyle.stokes2
wow that really worked thanks
- de damienjeffgomez
How can I transfer my data while in safe mode? I don’t see an option to do so, but Kyle stokes makes it sound like you can plug in a usb storage device and transfer the data during the initialization process? Does an option come up after starting the initialization?
- de Jarod Janner
Mostrar 3 comentarios más
