Saltar al contenido principal
Cámara de acción a prueba de agua (modelo no. CHDHS-101) lanzada por GoPro en julio de 2015. La Hero4 Session graba videos de 1080p y fotos de 8MP.
Preguntas 24 Ver todo
Looking for the internal lens assembly. I have it completely apart.
I smashed the internal lens of my go pro session 4. I have taken it apart and don't know where to purchase the lens assembly. I figured the lens assembly and sensor will need to be purchased together because the lens is glued into the assembly probably for focusing. I was able to get it screwed out but figure there will be no way to refocus it with a new replacement....
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I was wondering also if one of the two will work since the sensor size is supposed to be the same:
GoPro Hero Lens
[producto vinculado inexistente o deshabilitado: IF300-109]
I am about to receive a cracked lens Hero Session and will followup with what I find.
You should be able to refocus by using a calibration target to make sure image lens is screwed to correct position for proper focus, then maybe hot glue in place:
http://www.vision-doctor.com/en/line-sca...
Imagen de GoPro Hero Lens
Producto
GoPro Hero Lens
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
So, were you able to replace the lens?
- de
Yes, in regards to the outer lens. No, wasn't required regarding the inner from what inspection I've performed so far.
I found the outer lens destroyed and the inner lens wasn't in as bad of shape as the listing noted. I replaced the outer lens, invested in a aluminum 52mm lens adapter, a 52mm CPL and lens cover also. I haven't performed a thorough image analysis though.
Thankfully, from what I can tell that appears to be imperfect on the internal lens from a visual inspection... isn't observable in the images from a quick review.
- de
Añadir tu respuesta
Josh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 594
