Saltar al contenido principal
The Lenovo A7000 is a 5.5-inch Android smartphone released by Lenovo in April 2015. The Lenovo A7000 can be identified by model number A7000-a.
Preguntas 9 Ver todo
My lenovo a7000 won't charge and the computer is not recognizing it
So last night my phone had only 5% battery left so I decided to charge it in when I woke up at 3AM. Then when I woke up later in the morning there's no sign in my indicator that my phone is charging.
I already held the power button for a minute and cleaned the plug of my battery and plug it again in the charge but nothing happened. I tried another charger but it nothing happened too!
But when I tried the charger with other android phones they're charging. When I plug it in our computer the computer is not recognizing it.
What should I do? Need help. I can't factory reset it too.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 3
Agregar un comentario
4 Respuestas
Respuesta Más Útil
@lexylexander23 since you tested the charger on other phones, it does sound like it is working. Since it does not charge your Lenovo, I suggest that you start with installing a new battery. After that you will need to investigate the charging port on a board level and see if it is getting the voltage it needs and if it is connected. Power management IC's will be the last ditch effort. For any of those test you will have to disassemble your Lenovo this video should help you with that. Take a few images of the logic board etc. so that we can see what you see. Add those to your question by following this guide Agregar imágenes a una pregunta existente
Fue útil esta respuesta?
Puntuación 3
try to buy a new charger
or, repair the charger
Puntuación 1
1 comentario:
@ctaneshaa read the compete question "when I tried to the other android phones they're charging."
- de
You may hard reset your phone by switching it off and then hold the power button simultaneously alongwith the volume UP button. The phone should then restart and go through the initial setup procedures. However, even if that does not work for you, the next probability would be an issue at the motherboard level, or at the charging connector level.
Puntuación 1
Hello,
As i see your phone is not charged
some time this happen due to over use you phone your battery reached in a dead mode state.
At that time you have to give a shock your phone battery via another recharge battery and when your phone battery have some charge to turn on your indicates then plug in into charger Then your phone automatiocally comes into charging position.
Hope this will help you
Thanks
Puntuación 0
Añadir tu respuesta
Dera estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 1,558
