Saltar al contenido principal
Versión actualizada de la Retina MacBook 2016. Modelo A1534, EMC 3099. Ahora presenta procesadores Kaby Lake más rápidos de hasta 1.4 GHz Core i7 con Turbo Boost de hasta 3.6 GHz y SSD hasta un 50 por ciento más rápido, y admite hasta el doble de memoria.
Preguntas 81 Ver todo
Can individual keys be replaced?
I have a few sticky keys on my 2017 MacBook. I think I have spilt something, I tried using compressed air and cleaned them with solution, but it hasn't worked. Is it possible to replace individual keys?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 4
1 comentario
I have a damaged E key and the cap came off. However when I depress the key it won't register. Would anyone know if a replacement key (including the key and hinge) should fix this issue. I was wondering if a single key replacement would work in this regard or I would need a complete keyboard replacement.
- de
Agregar un comentario
2 Respuestas
Respuesta Más Útil
You can buy individual keys online, yes... just google it. People mark it up because they know about folks like you that need single units. They're easy to put back on.
When I messed up a few of mine, Apple just replaced the whole top case, saying they don't do single key replacements.
Fue útil esta respuesta?
Puntuación 2
assuming you mean the keycaps then yes it is, look at step 7 here and you will find that they are held down by 4 small clips Desmontaje del MacBook Retina 2017
otherwise possibly but it might not be worth trying with the 1/10 repair score.
Puntuación 1
Añadir tu respuesta
Tara May estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 1,399
