The Xbox One Model 1698 Wireless Controller was released by Microsoft in 2015 alongside Model 1697. It has more features than a basic controller, such as, removable thumbsticks and metal D-Pad buttons. The controller is primarily designed for use on a console, but it can also be used as a PC controller.
Preguntas 13 Ver todo
Do I need a Windows 10 PC or will the Xbox customize the controller?
I want to customize my controller and I was wondering if a windows pc is required to customize the controller.
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 2
Agregar un comentario
1 Respuesta
Solución Elegida
The Xbox will allow you to customize your controller’s paddles (along with other buttons). What you will need to do is download the Xbox Accessories App. You can download the app on your Xbox by navigating to the 'Apps' tab on the Xbox dashboard. Then, in the ‘Search all apps’ bar, type in Xbox Accessories. The screen should display the Xbox Accessories App under ‘TOOLS’ which you can then click on and install. Once it’s downloaded, make sure to pin it so it will appear on your homepage. Finally, navigate back to the dashboard’s homepage and it should appear as one of your apps. As an alternative, you can use a PC to customize the paddles by downloading the Xbox Accessories App onto your computer; however, it requires that your operating system is Windows 10.
Fue útil esta respuesta?
Calificación 3
Añadir tu respuesta
Sukhdeep Singh estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 3
Últimos 30 Días: 14
Todo El Tiempo: 137
