Saltar al contenido principal
Repair guides and support for gas, electric, and human powered machines used to cut grass, whether push style, or ride-on.
Preguntas 1212 Ver todo
Lawnmower problem with Fuel pump
I have a lawnmower that gets veey little gas coming out of fuel line. I have replaced fuel filter,pump, and lines. Now I discover the line coming from crank case is blowing air instead of a vacuum voming through line. What could be causing this and how could I fix it
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Check line from valve cover for cracks and leaks. Set valve lash. Plus check compression on that side cylinder. Mine developed rust scarring on one side, blew smoke. Am re-ringing with oversize and bore. One thing that helped for a little while was running a gravity feed fuel cell on top of hood.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Tony Coleman estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 10
Todo El Tiempo: 159
