Saltar al contenido principal
Lanzamiento 2016, enero, identificado por el número de modelo K430T. El tipo de pantalla es la pantalla táctil capacitiva IPS LCD, 16M colores y una cámara de 13 megapíxeles.
Preguntas 40 Ver todo
My screen is cracked and chipped at bottom.
I have an lg k10. I was at work and dropped my phone on floor. The screen is cracked in different spots and chipped off at bottom corner. Can I just replace screen or what do I need to fix this problem?
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
1 Respuesta
Solución Elegida
Assuming it is just the screen assembly that needs to be replaced you should be able to find a replacement part online readily. I would normally recommend getting the part on the plastic frame if available. They are relatively inexpensive phones and screens look to be in the $40 range, this device might be more inexpensive to replace. If that is the route you take please recycle the device.
How to disassemble LG K10?
http://www.ebay.com/itm/New-For-USA-5-3-...
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
John lacy estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 12
Ultimos 30 días: 14
Todo El Tiempo: 1,227
