Saltar al contenido principal
Western Digital My Passport Ultra es un dispositivo de almacenamiento portátil USB 3.0 con capacidades desde 500 GB hasta 5 TB.
Preguntas 37 Ver todo
Why doesn't WD My Passport Ultra 2TB allow me to paste files.
I was intending to use WD My Passport Ultra 2TB as an Archive to backup all my files and folders. Unfortunately, it is not allowing anything to be copied or saved on it.
Please instruct how to change this.
Es esta una buena pregunta?
Puntuación 4
2 comentarios
What model Passport are you using and are you using it for Mac or Windows?
- de
My 2 TB WD Passport Model no- P/N WDBYFT0020BRD - 0A, i am using it in my windows 10
please help to resolve this...
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Hi katerine albarellos, first of all, what computer operating system are you using?
as S W mentioned, if it used for mac, you need to use disk utility to format it to either exfat or macos extended (journaled). If there is any current files in your external hdd, be sure to backup or make a copy , as re configuring the hdd partition, will result in data loss.
to be able to use for windows, what i had done is to use disk utility to spit into two partition, one is using macos extended (journaled) for time machine, misc and another exfat, which windows can write to it
http://www.mactip.net/guide-how-to-forma...
Fue útil esta respuesta?
Puntuación 4
1 comentario:
Format not an Option , Do you have any other solution...
- de
WD Universal Firmware Updater for Windows
may be this gone work for you….
Puntuación 0
Añadir tu respuesta
katerine albarellos estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 8
Ultimos 30 días: 28
Todo El Tiempo: 15,386
