Charging port got loose. Cant charge it anymore.
Cable charging port got loose .
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
The charging port is just floating inside there can't charge
por
Agregar un comentario
2 Respuestas
Solución Elegida
Hi Grace,
Try cleaning the dust inside the charging port of your phone with a toothpick buffed with sandpaper or any other plastic tip (I do not recommend using metal objects). If it doesn't work try another charger or get the port replaced.Hope this helps!!!
Fue útil esta respuesta?
Calificación 0
Comentarios:
Thanks Rohith! Its been with me only for a wk. I will probably have the port replaced. Just dont know where.
por
It shouldn't happen
por
you have to go inside and take out the 6 screws that hold it together, take out the 2 screws from that little black cover that you see and take out the board within by lifting it out. if the board is in good shape then you can push it into place and add hot glue to keep it there otherwise the part number is 20150404
Calificación 0
Añadir tu respuesta
Grace estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 2
Últimos 7 Días: 14
Últimos 30 Días: 47
Todo El Tiempo: 231
