Why is my MagSafe 2 charger randomly not working?
I recently bought this used MacBook pro, and initially it worked well. Then I started noticing that the fan randomly speeds up even though the MacBook is cool to the touch. So I used a software to manually set the fan speed and it showed me 0 RPM for the fan, and wouldn't manually change the speed. I did multiple SMC resets but no change.
After some time I started using development apps like Xcode and Android Studio, and the MagSafe charger stopped working. At first I would reconnect the plug or the connecter and it would start working. But now the charger doesn't work for hours.
I use the charger when the battery is around 20%, I plug in the charger and the connector and there is no green or orange light, nor is there any reaction on the MacBook.
Then I took the same charger and connected it to my brother's brand new MacBook (2015 Model) and the light turns on. But when I use it on my own afterwards, my MacBook doesn't charge.
Then I tried my brother's MacBook charger on mine and that worked, my MacBook started charging. After about 2 minutes I used my charger and it started working as well. This has happened multiple times so far and I can't figure out what the problem is.
My charger even started working after I used it on a friends MacBook Air and then immediately on mine. That only happened once and I don't know why.
Is there anyway to figure out the actual problem? Should I get a new charger?
Also I live in a country where it's hard to find reliable persons for repairs or replacement equipment and hardware.
Es esta una buena pregunta?
