Saltar al contenido principal
Información de reparación y soporte para la computadora portátil Acer Aspire E15, lanzada por Acer en 2015. Número de modelo: E5-575-33BM.
Preguntas 82 Ver todo
How do I fix my right hinge: no longer attached to screen?
The lower right hinge is no longer attached to the screen. Every time I open my laptop it pops out of place, and I must push it back in, but it still remains loose and will pop back out anytime. I removed the frame of the screen and discovered that the hinge is attached to the screen by two means: screwed into glue (wtf? really?) and a metal column spanning from the top right corner (screwed in) to the hinge itself (used metal "hammer," can't simply unscrew and replace: again wtf?). I believe this is a simple repair job I can do myself but I need the parts. Where could I get those? I don't want to send it into a repair shop that will charge me 100+ for something so simple to fix. Thank you.
Update (09/10/2017)
Here are 3 images. Notice, the metal rod is snapped at the lower right corner that would normally stabilize the screen. Also, the hinge itself is no longer connected, as it was only glued to the screen.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
1 comentario:
Could you please take a picture and attach it to the post?
- de
Agregar un comentario
1 Respuesta
Does the hinge itself still move? It's just broken to where the hinge attaches to the laptop right? If so use JB weld. You can get that at the hardware store.
Fue útil esta respuesta?
Puntuación 0
2 comentarios:
Yes the hing still moves. I purchased the JB weld from walmart. I'm afraid that the glue will be an issue long term if it is not a permanent solution. Will the glue come off? Also, will it affect the wires that run near that area?
- de
It should be fine for long term as long as you let it cure. I know techs that use it without issues. It will not effect the wires. Best of luck!
- de
Añadir tu respuesta
erik keating estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 13
Todo El Tiempo: 2,825
