Saltar al contenido principal
El iPhone 5c de Apple fue anunciado el 10 de septiembre de 2013. La reparación de este dispositivo es similar a los modelos anteriores, y requiere destornilladores y herramientas de entrometimiento. Disponible como GSM o CDMA / 8, 16, 32 GB / Blanco, Rosa, Amarillo, Azul y Verde
Preguntas 1232 Ver todo
Won't charge, says This accessory may not be supported.
So here's the story; phone poorly taken apart, damaged chips, managed to get it to work but won't charge. One of the charging ics which I forget the name (9 pins, MOSFET, controls charging) was missing and had 3 ripped pads. Replaced that, now phones recognises charger bit says this accessory may not be supported, before would not recognise it at all. Not showing on pc at all. What should I replace next?
Es esta una buena pregunta?
Puntuación 1
1 comentario
Hey Giga, I just noticed this question. If you haven't fixed this yet, please let me know which IC exactly you replaced so that I can help you out.
- de
Agregar un comentario
3 Respuestas
Solución Elegida
@refectio i just used the board as a donor, used almost all the parts.
Fue útil esta respuesta?
Puntuación 2
1 comentario:
Cool, at least you put it to good use.
- de
1. Remove any debris from the charging port on the bottom of your device.
2. Restart your iOS device.
3. Try a different USB cable or charger.
4. Make sure that you have the latest version of iOS.
5. Contact Apple Support to set up service.
Puntuación 0
3 comentarios:
No, read the OPs original post. He took it apart and messed with the internals. It has nothing to do with a dirty charge port or bad cable/charger.
- de
This is unforunately the help you get in Apple forums.... a generic stupid easy answer that doesn't answer any of your questions.
- de
Apple support is always giving basic unrealistic solutions to your problem, where in the world did you need latest software to have a well charging phone?
- de
I Absolutely agree John
Puntuación 0
Añadir tu respuesta
Gigabit87898 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 44,079
