transfer data to new hard drive
Mac book pro 13 inch mid 2010
transfer data to new drive
Es esta una buena pregunta?
This question is very sketchy. Basically you will need a USB to SATA adapter. Hook the drive up. Use Disk Utility to format it GUID, MacOSX extended. Install a system onto it from your main internal drive. Now reboot from the external drive by holding down the Option key on Boot. You can now use Migration Assistant to move all your data. By doing to this way instead of cloning you get the repair partition installed. The drive is now ready to put into another machine.
Here's an adapter that Walmart carries for $8.12 https://www.walmart.com/ip/USB-3-0-to-SA...
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 537
