Saltar al contenido principal
Lanzado el 19 de septiembre de 2014, este iPhone de pantalla de 5.5" es la versión más grande del iPhone 6.
Preguntas 1525 Ver todo
iPhone 6 Plus sometimes gets stuck in bootloop
Sometimes when I boot my iPhone 6 Plus, it shows the apple logo and then it goes off, shows the apple logo again and so on... Sometimes it starts after a few attemps and other times I have to force a reboot a few times with Power and Home Button to get it working again. When it starts successfully everything works fine.
What could the issue be?
Es esta una buena pregunta?
Puntuación 1
2 comentarios
when the problem started?
- de
About the reboot loop issue, there are some questions raised as follows. This article will answer them one by one. Read on, you may get some ideas of what you should do when your iPhone stuck in bootloop, or said keep restarting.
https://www.forecovery.com/fix-ios/iphon...
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Many things can cause a boot-looping device. Please give us more history of the device, like whether it was subjected to drops/impacts, water or previous repairs by commenting on this answer.
When it is in a boot-looping mode, this is what I would normally recommend:
  • Try a hard reset (Home & Power button for 10 secs)
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Try to connect it to different computers (mac/pc if possible) with an updated iTunes
  • Put the phone in recovery mode (search DFU Mode). Careful, this can reset your data
  • Use 3uTools for putting it in and out of Recovery Mode
  • Use 3uTools to flash the firmware (you can't downgrade)
  • Check the condition of all the flexes (with magnification)
  • Disconnect the Front Camera Ribbon from the logic board and reboot your phone
  • Disconnect the screen assembly completely and see if iTunes will recognize the phone.
Unfortunately, your problem is intermittent in nature for now. It may get degenerative with time so you may have a logic board issue. If you are uncomfortable doing these steps, consider finding a repair shop to do the troubleshooting. A shop that also does micro-soldering can go deeper if the problem is not modular in nature.
Fue útil esta respuesta?
Puntuación 5
3 comentarios:
Thank you for your answer. The phone has never had contact with water, wasn't dropped and hasn't been repaired. I already flashed the firmware with itunes and reset the device, connected another screen without homebutton and camera flex and still the phone doesn't always boot successfully.
- de
Then you should have this looked at by a repair shop that does micro-soldering.
- de
What I noticed, that sometimes when the phone boots up, the apple logo disappears and there is a small dotted line on the right side of the phone. Could it have to do something with the graphic chip?
- de
I have the same problem my phone goes to a freeziny mode and none of the bottoms work so I have to simontainiously push both home and power a few times until it starts working wish really gets scary I only had the phone for two years and this happened every time
Puntuación 0
Añadir tu respuesta
ppalfinger estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 1,331
