Saltar al contenido principal
Guías de reparación y soporte técnico para los iMac Intel 27" de Apple, presentados en octubre de 2009.
Preguntas 3400 Ver todo
Why is not powering though there is just one led light on the board.
My iMac 27 is not powering, I opened it and discovered that there is one led light on when connected to power outlet but other three led are not, I checked around the board to me everything is intact but can't figure out why is not powering when I press the power button. Please what next should I do to rectify this issue.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
All the #1 LED indicates is that there is trickle power getting to the power supply. This does not means the power supply is working. I'm 98% sure you will need to replace it. But to get you to the correct part and guide I need to know your exact machine. There are two numbers on the bottom of the stand used to identify. One is an EMC number the other a model number and looks like: Axxx
If you can give us those numbers we can get you tot the part and guide.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Engr estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 39
