Saltar al contenido principal
I have had these for 8 months now, the left part of headphone has no sound now so I want to fix it myself because I bought in USA and i’m in another country now so I can’t send it to JBL to fix them. I know there is a connection issue with the wires because the sound was coming and going again in meantime but at the end it stopped coming. I know that ear pads are replaceable since I just don't know how to detach them. Please help
Preguntas 1 Ver todo
How to replace ear pads for JBL Everest Elite 700?
I have had these for 4 months now, the leathers of the ear pads are starting to come off slowly, from inside the cups themselves, and from the outside on the edges. I know that they are replaceable since I can buy new ear pads online for these headphones. I just don't know how to replace them. I can send them back to JBL for repairs, however it's just ear pad replacement, and I can do it myself. I'd rather not send for and not have headphones for weeks. Please help
Es esta una buena pregunta?
Puntuación 1
1 comentario
Im not here to answer i had this headphons for a year oe moee and not just did the leather was $@$* it also tore apart and i can see the freaking sponfe that they put inside
- de
Agregar un comentario
4 Respuestas
Solución Elegida
Here’s a series of pretty good videos on doing it in four parts:
https://www.youtube.com/watch?v=st8OdaOP...
https://www.youtube.com/watch?v=w5a5gaX2...
https://www.youtube.com/watch?v=IuUMNLH3...
https://www.youtube.com/watch?v=24YkD7JC...
Here are the replacement pads: https://www.amazon.com/Replacement-Evere...
Fue útil esta respuesta?
Puntuación 3
Respuesta Más Útil
From JBL.com
It is possible to replace the ear pads, but there are details to consider.
On Elite 700: The ear pads are held in place by a plastic plate with claws, and some of the claws will most likely break off when you remove the pad.
You do this by grabbing under the edge where the fabric ends, then pulling hard outward.
The claws will eventually let go, and some of them will break off, rattling inside the ear pod.
The only way to get them out is to unscrew the speaker plate, lift it up, and shake out the broken-off claws.
The new pads are simply centered over the speaker plate, and the claws pressed into the holes with a firm pressure.
On Everest 700: The ear pads are glued into position with double-adhesive tape.
Pull the old pads off with a forceful, steady pull, until the glue lets go.
Remove the protective layer on the new pads, and carefully position them correctly before pressing home all the way around the edge.
Puntuación 4
4 comentarios:
Where does one find the ear cushions? Can someone supply a link ?
- de
Please provide a link thanks.
- de
You can contact JBL support here "https://www.jbl.com/support-contact.html..., they will direct you to the nearest store to you that has spare parts. I just got mine replaced the other day :)
- de
So my JBL elite 700 earpads looks terrible now. anyone knows where can I get those earpads ? Thanks so much
- de
To replace the ear cushions, pick one corner, preferably the upper part of the oval. Then, from the inside of the ear pad, feel the plastic and push it out and slightly up. It should pop out as the plastic is designed to clamp the center. The idea is to push the clamps away from the center one at a time. I was able to do this on my JBL Everest Elite 750 NC without damaging anything.
Puntuación 2
Hi! Put something sharp to the tiny gap between the pad and the earphone itself. Twist gently.
Puntuación 0
Añadir tu respuesta
Subhaa Chandar Arumugam estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 7
Ultimos 30 días: 43
Todo El Tiempo: 13,630
