Saltar al contenido principal
Disassemble speaker to repair charger port
I am trying to repair my Techlife BeatBlock portable Bluetooth speaker, but I can't seem to figure it how to get to the circuit board. Does anyone know how to disassemble this product? It's been drying nuts for months. But, because I haven't found any videos at all, what so ever. It's gotta be well worth the repair.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 2
Agregar un comentario
4 Respuestas
0.You will need a flathead and philips screwdriver.
1.flip over your beatblock and take off the grips you will need a flathead screw driver there will be a hole under one of the grips shaped like a rectangle and in the hole a piece will be sticking out push it in with your flathead until the side that says beatblock closest to the hole pops out.
2. then you will see two speakers take the cloth piece that's around the speakers and unsrew with philips screw driver.
3.pop out the speakers tray and the curcuit board will be in one of the corners.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
i hope it helps
- de
I’ve taken one apart to do the same repair only to find that the port was a soldered component of the circuit board (a repair above my skill level). It was a strange disassembly if I remember right, almost as if the assembly process was meant to be a one way street. So, start by gently prying the outside speaker grille away. From that point, check to make sure I remember right, but I believe I took a flashlight and looked thru the secondary speaker grille screen. Under that, I believe found that there are 4 screws, one in each corner that are only accessible by drilling holes thru the speaker screen. Its a pain in the ass. Then after screws are removed the back panel comes off and the circuit tray is up top. Wiring probably has to be disconnected to fully remove the circuit board.
Puntuación 0
3 comentarios:
Oops. That disassembly rundown was for the beat block twins.
- de
how did you take apart Rugged wireless speaker apart
- de
take whatt?...leave the who??...I'm gone??
- de
What ‘I’ did - and this could have been a different brand, which wouldn’t have mattered I’d have tried doing the same- was after i almost tore it up, I located the 2 little red and black wires running to the port, took an extra USB CORD I had from an old rechargeable flash light ( I chose that cord knowing it wouldn’t have a bunch of multicolored wires included) and direct wired it. Thinking about it, I’ve actually successfully wired 2 Bluetooth speakers back this way. A catch would be if your speaker has its own power cord with adapter. I’ve been lucky and both were 5 volt so a phone block worked.
Puntuación 0
1 comentario:
How can I open and repair my Gionee groover Bluetooth speaker
- de
How can I open my Gionee Bluetooth speaker
Puntuación 0
Añadir tu respuesta
Kimberly estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 32
Ultimos 30 días: 168
Todo El Tiempo: 13,413
