The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
Preguntas 161 Ver todo
Spilled MacBook Air 13 2015 doesn't work without charger
Hello!
I have spilled MacBook Air 13 2015 with beer. I have disassembled it and cleaned it with cleaner and alcohol. There are no visible damages on boards.
It doesn't work without charger. However it sees battery. When it works with charger red light is on (not green).
Here is some info from About This Mac:
Battery Information:
Model Information:
Serial Number: C016053025YF90MBY
Manufacturer: DP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 511
Hardware Revision: 000a
Cell Revision: 1200
Charge Information:
Charge Remaining (mAh): 3837
Fully Charged: No
Charging: No
Full Charge Capacity (mAh): 6605
Health Information:
Cycle Count: 129
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 7785
And some screenshots:
What could it be? Is it possible that charge management chip is damaged?
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
Kits de Mac RAM
Acelera tu Mac. Maximiza su memoria.
Kits de Mac RAM
Obtén más memoria para tu Mac.
3 Respuestas
Solución Elegida
Just needs the battery. Whenever the battery status is showing "replace now" or "service battery", etc, the issue is with the battery, nothing else.
Fue útil esta respuesta?
Calificación 1
Respuesta Más Útil
I'd get into an ultrasonic cleaner. You may need a professional one this one.
Calificación 1
Hi, please I have similar problem.
I replace my logic board on my macbook air 13' early 2015 i5 4gb ram.
And now only turn on with charger, if I disconnect the charger, then macbook air turn off.
System Report shows that the battery is installed (217 cycles), but say: "Battery is not charging".
Please, I need you help.
Thanks.
Other data: The macbook air was turn off about 60 days with battery disconnected from logic board, until that the new logic board was arrived.
Battery in sleep ??, Battery needs reactivate??, what happened ??
Calificación 0
Añadir tu respuesta
Alex F estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 1
Últimos 7 Días: 2
Últimos 30 Días: 13
Todo El Tiempo: 235
