Repair guides and support for your Samsung TV.
Preguntas 949 Ver todo
Vertical lines on tv
There are colored vertical lines running down the entire length of my samsung plasma tv screen. Here is a picture of the screen, including model no.
http://imgur.com/BfyDquL
Any help is appreciated!
edit: The colors in the background are only there to display the picture easier, that is not part of the problem
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Im alittle late seeing this post. Just dont want anyone to get the wrong idea here. LCD panel is not a bad guess if it was an lcd tv. Plasma is charged ionized gases aka plasmas. You have 4( charge) control boards. Top bottom left and right. Vertical bars appear from corresponding boards. (top,bottom). Horizontal bars (left,right,. I dont know your skill level so you can replace the board after confirming the fault. Or you can repair at component level. Get a schematic and troubleshoot the diodes first. Then check for voltage leak at the transistors. Continue until fault is found
Fue útil esta respuesta?
Calificación 1
Respuesta Más Útil
This is a broken LCD. The LCD would need to be replaced. This issue is usually caused by some sort of impact that hit the TV too hard. The LCD is essentialy the TV, honestly you are better off with a new TV as these parts can be hard to come by. Hope that helps and good luck!
Calificación 1
Añadir tu respuesta
Dylan Powell estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 15
Últimos 7 Días: 95
Últimos 30 Días: 394
Todo El Tiempo: 1,765
