Saltar al contenido principal
Información y guías de reparación para el iPhone 6 que salió a la venta el 19 de septiembre de 2014. Números de modelo: A1549, A1586 y A1589
Preguntas 4994 Ver todo
Need help cleaning water damaged logic board
Hi, today I received a water damaged 6 and was asked to fix it. I have taken out the logic board to see if there was any visible issues, and I can see something on the back. Can someone tell me what this is, and how to fix it if possible?
Thanks!
Es esta una buena pregunta?
Puntuación 2
1 comentario
@ef123 the first thing you want to do is to remove the EMI shields so you can really see what you are up against. After you removed those shields try to take some clean well-focused images so that we can help you to evaluate the damage. Right now it's a lot of guessing.
- de
Agregar un comentario
1 Respuesta
Solución Elegida
Those flare marks are caused by the adjacent caps that are filtering vcc_main and the nand power rail. That tells me that this is where the water shorted the vcc-main line first.
As @oldturkey03 says, the shields have to come off followed by a proper microscope inspection. Then a bath, rinse and dry. Only then can you start probing and trying to determine what the issue is. Many water damaged phones can be saved if they were attended to quickly and professionally. Just because some shops wont touch them doesn't mean they should all be trashed. Despite the poor quality of the images, this one doesn't look that bad to date, there isn't even any corrosion on the connectors.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Ethan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 2
Todo El Tiempo: 176
