Apple released the MacBook Pro 15" Retina with a new display that has a 2880-by-1800 resolution.
Preguntas 1265 Ver todo
verify server server id
cannot verify server identity
Contestado! View the answer Yo también tengo este problema
Es esta una buena pregunta?
Calificación 1
Comentarios:
You'll need to give us a bit more here...
por
Agregar un comentario
1 Respuesta
Solución Elegida
I assume you are trying to connect to the internet and during the connection a pop up a warning dialog box stating this "Safari can’t verify the identity of the website (URL)"
The first thing here is make sure your systems date & time are correct. Go into Date & Time preferences and make sure the 'Set date and time automatically" is checked and the time server is set to one of Apples servers.
You may also need to refresh your systems DHCP lease. What likely has happened here is the DNS server connection is not getting though the host (server) you are trying to connect to is one you have accessed before so the cached values are getting you there but the DNS connection failed to double check.
Heres a write up from OS X Daily that goes over some of the issues if your settings are correct as your connection could be being spoofed! Fix a “Safari Can’t Verify the Identity of the Website…” Error Message
Here's a bit more on DHCP & DNS:
Fue útil esta respuesta?
Calificación 2
Añadir tu respuesta
David Napchi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 Horas: 0
Últimos 7 Días: 0
Últimos 30 Días: 1
Todo El Tiempo: 32
