Power Pads on a 1398 Mid 2015
Does anyone know the location of the power pads for this model Macbook Pro?
Es esta una buena pregunta?
Unless you have some specific need for the power pads, I suggest plugging an 85W MagSafe 2 original charger. This is all this model needs to power up when the battery is unplugged, or after the battery has been unplugged then plugged back in.
And it will boot without peripherals such as keyboard or trackpad.
If it does boot without the peripherals, then fail to boot with any of them re-connected, you would know you have a suspect part.
Fue útil esta respuesta?
@rany you might want to stick with phones. The OP is looking for the two spots on the logic board that when shorted will cause the machine to boot. Obviously his machine is not booting when pressing the power button. This is most often caused by a liquid spill that has shorted out the keyboard.
@mayer how do you prompt a 2015 MacBook Pro to boot if you don't have a keyboard attached?
@mayer what's wrong with @rany's answer? It will boot when plugging the charger in (after the battery is reconnected), so if it boots this way (with the keyboard plugged in/unplugged, in case this is preventing boot) OP knows it is a keyboard issue.
This is by far the easiest way to check for a bad keyboard, I work on a lot of MacBooks daily and never have had a use for finding the power pads; no need when it boots up by itself when the charger is plugged in.
@rany FYI, the fans will spin straight away on the 2015 15" when booting, it is only the 2015 13" where the fan will spin once it needs to cool down :)
Thanks @reecee, I edited the answer to remove the part about delay in fan spin.
I think you are missing a step in the original answer. I think it should say that after disconnecting and reconnecting the battery, the machine will boot upon connecting it to power, without the need of pressing the power button. Is that correct?
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 4
Todo El Tiempo: 1,325
1 comentario
do you have a motherboard number like 820 xxxx?
- de Oros
