Saltar al contenido principal
Lanzado el 25 de septiembre de 2015. Modelo A1688 / A1633 . La reparación de este dispositivo es similar a las generaciones anteriores, que requieren destornilladores y herramientas de palanca. Disponible como GSM o CDMA / 16 , 64 , o 128 GB / plata, oro, gris espacio, o la opcion de oro rosa.
Preguntas 2693 Ver todo
Should I replace the logic board on my iPhone 6S?
The iPhone 6S was working fine the night before but in the morning was dead.
Tried doing a hard reset, the screen flashed for 5 seconds and went dead.
Apple store diagnostics said phone is not repairable.
Took to a cell phone repair shop and tested with new battery and display - it did not come on.
The only option is that the logic board could be out.
Should i attempt to fix logic board? Is there anything else I should try before I fix the board?
Thanks
Dan.
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Solución Elegida
The iPhone 6S is still a very valuable device. I would certainly consider having the Logic Board repaired. Most shops that specialize in micro-soldering use a no fix/no fee pricing model so you don't have much to lose. You can check out my profile for more info or search google for other shops that also do no fix/no fee..
Fue útil esta respuesta?
Puntuación 4
3 comentarios:
Can I mail it to you? Live in US..
- de
Have you been charging with a non original charger? I ask because the Tristar (USB Charging IC) is known to go bad when you do. You have checked the Charging port I assume? Minho is second to none when it comes to iphone repairs and is well known here on Ifixit as the "Iphone God", lol...You can search for local business that perform Micro-soldering and are reputable but they are far and few between.
- de
@njayaram, sure, check my profile if you want to reach out to me directly.
As @teetopp mentions, you may find a good micro-solderer in your area if you Google "micro-soldering your city/state/region". There are several awesome micro-solderers out there, some of them are active on this forum (including Michael), others use different avenues to share their knowledge (Youtube, Facebook etc.). As for me, I bleed and hurt like everyone else...so I am no god :-).
- de
Añadir tu respuesta
Nan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 198
