Saltar al contenido principal
Top half of screen darkened
My HD75 - UN75F7100 top half of my screen has begun to darken.. I have uploaded/updated software and did a complete reset... but still the upper half of the screen has this darkened area completely across the top and approximately 1/3 to 1/2 of the screen... serial number is Z7MS3CADA01667D
Update (07/18/2017)
This is what screen looks like
Es esta una buena pregunta?
Puntuación 45
64 comentarios
Is it a darker area, or is there a thick black bar at the top of the display?
- de
There is a black bar that I can see through but causing the top half of the screen to be darker than the bottom half..
Called Samsung and they ran diagnostics remotely and said it was not software issues, but hardware... talked with the electronic service rep and he believes it's the screen and it would be close to $2000 to have it fixed..
So what do you think is it hardware/screen or ?
- de
Thanks... after talking with a company service tech... he basically said the same thing... and me not being someone who wants to tackle something of this nature on my own.. and his
statement that I would have to replace the LCD panel and that cost being close to what a new one would be... we decided to go with a new one. But I totally appreciate the replies... and you have been very helpful.... one final question.. I have purchased a Samsung 8000 QLED series but besides the 1 year factory warranty, can any other factory service agreements be purchased from Samsung?
Again thanks
- de
Back to the un75F7100 same problem with mine and its only 2 yrs old, I purchased an extended warranty from Frys and gonna check with them this week about having it fixed hopefully they will honor the 4 year extented warranty. If you are interested to know what happens post a comment and i will follow up Thanks
- de
Im having the same issue as well, did you ever solve the problem, It happened out of nowhere and I figured it was just the darkness from switching the TV input as the HDMI selections show up in that exact portion of the TV but one day it never went away, I didmt do any software updates, because truthfully I didn't know you could haha but I also assumed its the screen, which if thats the case I'll buy a new TV....It'll be %#*@ hard to throw this one away tho : (
- de
Mostrar 59 comentarios más
Agregar un comentario
15 Respuestas
Solución Elegida
I had this problem too... and fixed it in about 10 min. I searched the internet for this problem and found many forums with pretty much the same resolution... REPLACE TV. I find it interesting that in almost every single case I read over the last 24 hours... no one... absolutely no one recommended a simple Problem Determination (PD) procedure to quickly determine if the issue was in the TV or outside the TV.
Supposedly people spoke to techs on the phone, which in most cases are reading from a tech manual... or try to dial in and update TV firmware remotely... what I didn't see or read is where someone actually had a repairman look at it.. or did actual PD to eliminate issues with cables or devices connected to the TV.
My Curved Samsung UN55JU6700 among several other devices... is connected to an Xfinity HDR and through HDMI cables. So.... the first thing I wanted to do was to see if the problem went away if I changed channels... it did not. Then, would the issue move when using another HDMI source...
I turned on my APPLE TV and switched to that as the source. I immediately noticed that the issue appeared to go away... so for grins, I tried my DVD player... and still the problem did not return...
Now I know its either the HDMI cable feeding the signal or the xFinity box itself... so I tried a different cable and the problem did NOT go away this time... Now I'm highly suspecting the Xfinity DVR device. I powered off the HDR but the problem still remained ... No I'm thinking Im going to have to spend an hour on the phone with a tech that knows less then I do... or spend an hour or two at the Comcast store waiting for a replacement DVR. SO BEFORE I did that, I tried one last PD step ... I decided to UNPLUG the DVR and let it do a complete POWER ON RESET ... in case something got hosed during the last firmware update.... 10 minutes later... my SAMSUNG is working flawlessly once again. DONE, FIXED (at least in my case).
So ... if your having this issue... BEFORE panicking from all these doomsayers on the net... that in many cases sell or repair TV ... try some simple PD ... hopefully you'll be lucky like I was.
Fue útil esta respuesta?
Puntuación 119
128 comentarios:
Good day, Ray.
I'd like to ask you because you seem to have the most experience in these kind of things, but I have faced your problem and the repair guys are asking quite a lot from us. I followed your steps, but the problem persisted. What do I do now?
- de
worked great. It was cable signal. thank you
- de
You have saved me so much money , time and aggravation.
Thank you Tony for the cable box reboot fix...it worked
- de
Oh my gosh! I turned off my Xfinity router, and when unplugging it, noticed it was very hot. But I turned on my LG led tv without using the router, and used my Netflix app instead, the dark bar at the top had just gone away!
- de
SAME thing just happened with our 4 yr old Panasonic TV-rebooted the Xfinity box and the dark area is gone! Thanks
- de
Mostrar 123 comentarios más
For my TV it turned out to be the cablebox . I ran a picture test with the tech. , and the picture was fine. I rebooted the cable box and it went away!
Puntuación 27
32 comentarios:
I reset my cable box and it went away. Yay!
- de
This was so helpful! Thank you for saving me the cost of a new tv!
- de
Worked for us as well. Thank you!
- de
You are the bomb! It worked perfectly! Thx!
- de
Unplug the Comcast DVR/Box and plug in after 10 seconds or so, and the dark band on the top went away. Must be the Comcast software that was just updated caused the problem. Comcast must inform their customers before they spent thousands of dollars for a new TV or repair something that did not have any problem. Shame on Comcast.
- de
Mostrar 27 comentarios más
Be sure to scroll down this string. If you have Xfinity boxes through Comcast, there's a good chance all you have to do is push the reset button on your cable box. After running through all the reset options for the TV and its various display settings, I read Ray Negron's post. He suggeste a VERY simple fix that worked great for me. Just hold the reset button on your Xfinity box until the blue power light goes off. Wait 20 seconds and repower the device by pressing the reset button again. Shadow across top of set disappears.
Puntuación 10
6 comentarios:
Jim my TV turned black at the top. I have Xfinity from Comcast. I pushed blue button and let it alone for 20 seconds. It worked, thanks for the tip.
- de
Thank u so much, this worked for my directv setup!! Made my day
- de
LG SmartTV….dark shadow across top. Xfinity Comcast. Unplugged box waited about 8 minutes plugged it back in, took about 3 to 5 minutes to come back up! Shadow “GONE!” Thank you
- de
Omg thank you I reset my cox box bam all gone. At dist I thought I had to do some black Friday shopping nope not this year
- de
Thank you very much! Rebooting our Comcast box fixed the problem. We thought we would need a new TV.
- de
Mostrar 1 comentario más
I unplugged everything.... cable box, HDMI cable, TV & even my modem/router.... waited 10 minutes then powered back on & haven't had the trouble since.
Puntuación 4
1 comentario:
Nearly new, Sony TV. Reset Xfinity system, resolved issue. 👏🏻👏🏻👏🏻
- de
Unplug everything associated with your tv. Wait a minute, then reconnect things. Problem solved with my Samsung 4K.
Puntuación 3
Tony Sinclair that looks more like a bad LED backlight strip. For that you will have to disassemble your TV and the LCD panel. Not a fun thing to do but possible. Of curse you do want to check all the wiring specifically the wiring on the power board. Post some images of your boards and the data label on your LCD panel. Post those with your question. Here is the guide for that Agregar imágenes a una pregunta existente It will let us see what you see.
Puntuación 2
Tech repaired Samsung Smart TV this week for powering off issue. Regarding the shadow on the top 1/4 of the screen, he agreed with the source of the problem being the Xfinity HD box. This because the shadow does NOT appear when streaming (e.g. Netflix; Amazon, etc.) OR a DVD from the Blu-ray. He suggested requesting a new box. (But I won't since I"m ditching Xfinity and going to YouTube TV)
Puntuación 1
2 comentarios:
Genius!!!!! Thank you thank you thank you!!!!! I love you!!!! God bless you!!
- de
What if the problem occurs while Netflix is on
- de
I had a problem with a single, slim, and kind of blurred looking darker line 1/4 to 1/3 of the way down my screen. I would describe it looking almost like the screen had an indentation or fold more than anything else since the picture underneath seemed fine.
I do have xfinity so I tried many of the solutions here. None of them worked and I was starting to get concerned. Being a bit of an extreme troubleshooter I dug into TV settings.
I noticed that when I changed various brightness levels the line would move up and down depending on the brightness, with brighter settings pushing it higher but never eliminating.
If your Samsung TV has an eco friendly setting to adjust brightness based on ambient light, try disabling that setting. It removed the line I was seeing. Seems like a bug and not a feature in this case. That faint line was driving me crazy! I can’t understand why that was the cause. It was almost as if it was applying a darkening gradient over the entire picture to cause it to emit less light.
Puntuación 0
1 comentario:
In TV Technician terms we call it a vertical foldover. There is a probable failure in one or more components(maybe capacitors, transistors or ic maybe) in the vertical section of the board. Problem is where to find which section of the board it is located, unlike, before different sections of the TV has separate boards but not now.
As you said being an extreme trouble shooter, try the solution I suggested Susan Hamson above if it works. Just a guess if you want to go into that route.
- de
SOLVED (for me). I had this problem all of a sudden and i realized it had to do with my TV's display of my home phone's Caller ID. To remove the banding, i simply called my home phone number to reactive the gradient and it went away! Yay.
here's the deal...my Cox Contour TV displays a caller ID whenever I receive a call to my home phone number. When this happens the top edge of the screen darkens into a blueish gradient. After the call is answered or ignored the caller ID and gradient (should) automatically go away. At some point i noticed a call come in and I ignored the call, but the gradient did not go away. At first i didn't realize to consider this, I was trying to find some setting somewhere. Then i remembered seeing that Call ID notification and thought it must have just stuck in the mode.
I was right. I just called my home number, saw the Call ID displayed on the TV. Canceled the call. The gradient went away.
I hope this helps!
Puntuación 0
2 comentarios:
(SOLVED) CALL YOUR HOME PHONE.... It is a "Caller ID SCREEN ISSUE"..... It worked for me!!!! : ) I was having the same problem on BOTH of my TV's. We first thought that the Samsung TV in the back room was just "old", but realized even our BRAND NEW LG TV was doing the same thing (dark at the top.). Hmmmm...... I then toggled and went to my HDMI 2 input (for my Apple TV). It was a perfect screen. I then knew it was a Comcast Issue and NOT the TV. I read the comments above, and saw KINRAW mention on 12/5/19 that the Caller ID "top dark screen" sometimes gets "stuck". Worth a try.... I called my home phone from my cell phone, and IT IMMEDIATELY CLEARED!!! What a relief!!!!! Hope this helps!!! : )
- de
@kinraw THANK YOU!!!! This worked for me with one call to my home phone!! Yes, it is a Caller ID Screen Issue with Comcast. Not a TV issue. : )
- de
Just had the same problem! Rebooted the box. Grey strip across top of TV gone!!! Thank you! thank you! Thank you!
Puntuación 0
1 comentario:
Literally just had the same issue with my Samsung HD Smart TV. Upon reading this thread I restarted my Xfinity box and sure enough, problem solved. Ironically this issue began about an hour ago when my remote control locked up (green light on cable box wouldn't go out) which further supports it likely being an Xfinity related problem.
- de
I had a 2 year old smart TV with the faster chip by Samsung. Same issue. Tried everything including swapping out the cable box, chasing my modem, changing all of the cable connections and it was still there. So, I bought a new 75" for one room, moved the other large screen to our family room and gave the faulty TV to my son who lives in his own apartment. He connected it to his cable box and guess what....no grey line! I don't think the issue is with the receiver. It is most likely the cable feed into the TV or some kind of radio interference. Try changing the HDMI and coax cables first. Power off your modem, TV and cable box. Change the cables and power everything back on. If that doesn't work, give the TV away. Good luck.
Puntuación 0
I have a Vizio D55-F2 with a darkened top half that appears exactly like the picture in the original posting. I disassembled the panel and replaced all defective LEDs, some of which fail open causing an entire strip to go out while others fail shorted allowing other LEDs in the strip to continue working. I tested all the strips before reassembling only to find the problem remained. I then began looking at the signals from the backlight PWM controller and saw that the darkened top strips were actually being PWM’d while the bottom half was full on. By luck, I disconnected the bottom strip’s 58V supply as a test and all other strips came on and, even at 50% duty cycle, it appeared to have a nearly uniform brightness. The darkened state also appears to stem from a possible power up test because the bottom LED row did not light when reconnecting the 58V supply while powered on and it appeared to be no PWM signal for that row as if it had been disabled. The 58V supply is from a very noisy switching circuit and I wonder if the fact that the mosfet for the bottom row is located right beside it could be affecting possibly the current sense going back to the backlight IC. It could also just be the backlight IC is bad, but it is a Novatek NT50511S for which I cannot find a data sheet. For now, I’ll live with it since the missing bottom row is hardly noticeable.
Puntuación 0
2 comentarios:
It's a problem with the cable box after an update, just power it down and then restart.
- de
thank you it was the cable box!
- de
Simply unplug the tv, and unplug the cable box. Wait 30 seconds and plug cable box back in. Wait a few minutes then plug tv back in. Power on tv and after cable box completely resets, the dark portion at the top of the screen is gone.
Puntuación 0
My samsung curve had the horizontal shadow about 1/4 of the top of screen. Tried everything and nothing worked until I tapped the back bottom portion of the tv and the shadow went away. Any idea what could be loose?
Puntuación 0
3 comentarios:
@georgesgebrayel loose connection on the LCD driver board or cold solder joints of one of the components.Only a guess since we do not know what it looks like or even what model this is. Definitely check for those things
- de
This is a known issue with these TV's. I have heard fixes form drive it around in your car to bang on the set. It is exactly what georgesgebrayel said. It is circuit related. Although I love this TV the curve is old and I just decided enough is enough. It is now the outdoor set
Get yourself a new one
- de
sorry oldturkey03 is correct
- de
Who know why my Samsung 55 curved one side looks faded color
Puntuación 0
1 comentario:
I have the same issue on my 70” Samsung, any luck?
- de
Añadir tu respuesta
Tony Sinclair estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 125
Ultimos 7 días: 731
Ultimos 30 días: 3,899
Todo El Tiempo: 604,659
