Saltar al contenido principal
Modelo de mediados de 2012, procesador A1278 / i5 a 2,5 GHz o i7 a 2,9 GHz.
Preguntas 1624 Ver todo
First aid found couruption that needs to be repaired
How do I fix the courption ????
Thank You
Es esta una buena pregunta?
Puntuación 0
2 comentarios
The image you posted shows some distortion is that what your screen looks like. If it is I think you have deeper problems here ;-{
Can you give us the exact model you have as Apple has quite a few different versions! Paste in your systems S/N here EveryMac - Lookup, then post the system URL link here for us to see.
- de
Mid 2012 13 inch pro with Samsung ssd 500gb the screen looks like that because I took a picture of it with my phone
- de
Agregar un comentario
2 Respuestas
Solución Elegida
Generally, You need to boot up under an external boot drive so you can run Disk Utility from it. This can be a USB, FireWire or Thunderbolt drive (depending on your exact model); or use a second Mac using Use target disk mode to share files between two Mac computers
While that can address minor issues, you may have a deeper hardware issue here. Like a bad drive and/or a bad HD SATA cable. But this depends on your exact model what is needed here.
Fue útil esta respuesta?
Puntuación 2
2 comentarios:
This worked thank you
- de
The computer always acted fine just that message was annoying lol
- de
Try booting into recovery by shutting down the computer and holding [command+R] during startup. Then repair the disk though Disk Utility.
Puntuación 0
Añadir tu respuesta
Collin.nesbitt@gmail.com estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 169
