Saltar al contenido principal
Right side of earbuds doesn't work
I've had these earbuds for about 2 months now, but after one subway ride. The right side of the earbuds doesn't work anymore. The right earbud has no sound, the in-line mic along with the controls doesn't work. It's not my phones problem because I tried using the same earbuds on different devices. FYI my left earbud has sound, that's all I have going with these earbuds. Fixes? Thank you beforehand.
I still have my warranty, but the shipping fee and all that trouble isn't really worth it. So if they cant be fixed what are good earbuds under $20? Thanks!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
This likely is not the answer, but have you pushed the end all the way in? I had that with my PC and noticed I only had sound on one side then when pushed end all the way in, it worked again.
Fue útil esta respuesta?
Puntuación 0
1 comentario:
Thanks for responding, i have pushed my earbuds in all the way. Thank you anyways :D
- de
usually with my pairs, the cord on the inside is damaged and/or broken. try putting the cord in different areas.
Puntuación 0
I have the same problem. I still had the warranty and I exchanged them. I have the new set of same ones and the same problem is happening.
Puntuación 0
2 comentarios:
I assume we are talking about stored music instead of online streaming. Some older shows and movies only come through one speaker (left side?). You have probably experimented with different equipment to make sure it is not coming from that. Sometimes too, the wire going to that earphone has been broken inside because people insist on wrapping the cord around things to store them. The cord inside separates easily and then it won't work. Try moving and wiggling the cord between your fingers to see if it connects while sound is on. That happened to my computer speaker when I tried to catch it from falling off desk and pulled on the cord. Now I have to lay the cord a certain way and tuck it under the pc for it to work sometimes.
- de
Sorry - I did not read your original post as to your specific problem. Maybe this will help someone with a slightly different issue.
- de
Añadir tu respuesta
Allen Plays Games estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 12
Ultimos 30 días: 68
Todo El Tiempo: 4,457
