Consoles no longer turning on after swapping internal memory
Hello there,
i have 2 consoles here with me, one of which has a cracked LCD and another that has a parental lock on it. out of curiosity i decided to swap the internal memory chips around to see if the parental lock was bound to the memory chip or one of the other boards. before removing the memory i made sure to disconnect the battery. once everything was all set up and ready to go i tried to turn them back on again to no prevail unfortunately.
any ideas or suggestions to help me here?
thanks!
Es esta una buena pregunta?
5 comentarios
slight update, i swapped the memory chips back, the one with the parental lock turns on again but the one with the cracked screen still does no turn on
- de James
I'm assuming you made sure the battery was fully connected and charged?
- de TronicsFix
you would be assuming correctly :)
- de James
Hello James, would you happen to still have one of these systems with you? I'm looking for a replacement part.
- de zacharywd
no sorry no longer have it
- de James
