Why is my charger never working and I bought it from a store
it won't ever work when i use it is it because I'm using a different charger?
Es esta una buena pregunta?
@madisonhope47, madison, Try another compatible charger and if it works in your phone return the new charger as defective or not compatible with your phone. If problem persist with known good working charger the problem could be the battery faulty or poor connection(check battery with DVOM, disconnect battery clean connection Qtip dampened with 90%+ Isopropyl Alcohol) and reconnect correctly/charging
port dirty(check for and remove lint), check for damaged pins and straighten carefully with tooth pick, loose may have to be resoldered or replaced. If all looks good the charging chip on mother board likely faulty. Link below is a partial disassembly guide that may help. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 46
